2007 chevy silverado 12v ignition sw
jae13
Posted: November 10, 2009 at 8:25 AM / IP Logged
I was installing a parrot ck3000 evolution with a quick connect harness in a 2007 Chevy Silverado (new body style) last night. Usually I pick up a fuse splitter and tap into something that would turn off when the vehicle turns off. I went to the fuse panel on the drivers side dashboard, went through each one and either they're dead (no power to the car kit) or the unit turns on and stays on. Is there anywhere I can tap into that will allow the bluetooth car kit to turn off when the truck is off? Thanks for the help!
Platinum - Posts: 12,488
Posted: November 10, 2009 at 11:13 PM / IP Logged
BROWN wire at the ignition harness. You will need to remove the steering wheel shroud to get to this wire or go to the base of the steering column and cut open the taped up wires and meter the BROWN wire there. This is an ACCESSORY wire BTW
You can vote in polls in this forum
