acquiring eight ohms
t&t tech
Platinum - Posts: 2,622
Posted: November 10, 2009 at 3:14 PM / IP Logged
I wanna connect two jbl eight inch, single voice coil subs, 4 ohms each, to an a/c reciever that's eight ohm stable on both channels, but i want to run them independently, meaning i'm not wanting to series the spekers to acquire the load, is there anyway i could achieve this? Sorry if the question isn't too smart! lol!
j.reed
Copper - Posts: 716
Posted: November 10, 2009 at 3:24 PM / IP Logged
You could run a 4ohm resistor in series with each sub to get the 8ohm load.
acquiring eight ohms - Last Post -- posted image.
haemphyst
Platinum - Posts: 5,059
Posted: November 10, 2009 at 5:00 PM / IP Logged
NO!
While this may be true, if you wire a woofer in series with a resistor, you will be dissipating HALF the amplifier's power in that resistor... Simple Ohm's law, dude...
If your receiver cannot handle 4 ohm woofers, you can't use them without wasting half of your receiver. To do it right, you are stuck with getting the proper drivers.
t&t tech
Posted: November 10, 2009 at 5:19 PM / IP Logged
Thanks fellas!
DYohn
Platinum - Posts: 10,741
Posted: November 10, 2009 at 5:26 PM / IP Logged
Buying some 8-ohm speakers is how I'd do it...
j.reed
Copper - Posts: 716
Posted: November 10, 2009 at 5:33 PM / IP Logged
haemphyst wrote:
NO!
Yes this is true. only HALF the power will reach the sub. the other half will go to the resistor but, it is the only way without changing the subs, receiver or running his current subs into series and only using one channel of amplification. It would fit the bill of his question to the T.
j.reed
Copper - Posts: 716
Posted: November 10, 2009 at 5:34 PM / IP Logged
This would be my choice as well.
sciullo779
Member - Posts: 12
Posted: November 10, 2009 at 10:19 PM / IP Logged
and noting the resistors, good luck finding one with that high of a wattage value lol
j.reed
Copper - Posts: 716
Posted: November 10, 2009 at 11:06 PM / IP Logged
Pretty easy to find up to 200watts. Seeing as this is a home receiver I see no problem finding one that will work. But as said above. I would just buy 8ohm subs and call it a day.
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
