2005 altima not starting
gad1116
Posted: November 10, 2009 at 3:41 PM / IP Logged
I am trying to install a remote start  on a 2005 nissan altima 4 cyl u\when I hit door unlonk the brain clicks when I try to remote start it I hear no click
I have not installed the control safety switch not sure where that wire is from the ecm do i need that to start the car and if so is there any way to bypass that switch or hot wire or somethin I can not find they wire from the ecm plus not 100% sure how to install that switch everthing else is hooked up though.
syl20rochon
Copper - Posts: 298
Posted: November 10, 2009 at 6:46 PM / IP Logged
The neutral safety wire needs to be at ground.....what kind of r/s are you installing?  You have to remember that you have 1 ignition wire, 1 accessory wire and 2 starter wires on a Nissan vehicule.
2005 altima not starting - Last Post -- posted image.
Also, depending on the brand of your r/s....if don't have virtual tach....you need tach and you need to program it...
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
gad1116
Posted: November 10, 2009 at 6:49 PM / IP Logged
thanks for your help you are 100% right i need to ground the netural switch now I need to install a tach wire and tips or hips as to where it is
syl20rochon
Copper - Posts: 298
Posted: November 10, 2009 at 7:15 PM / IP Logged
Do you have virtual tach?  If not, go to injections, normally there is a common wire on each...take the opposite and program the tach.
Sylvain Rochon
I'm here to help.
