Pit Stop Mode? Compustar
dswift
Copper - Posts: 396
Posted: November 24, 2009 at 6:30 PM / IP Logged
FYI,
In reference to all compustar remote starters and combos.
Pit Stop Mode feature aka Start and Go aka Whatever you call it.
Can it do it? Yes
1way remote: While car is running and key is in the ON position. Auto start the vehicle again while your foot is off the brake. You will  hear mutilple clicks in the dash board remove the car keys and the vehilce will remain running. This is for AUTOMATIC vehicles only.
2way Remote: While car is running and key is in the ON position, auto start the vehicle with foot off the foot brake. You will get a two way confirmation and then you can remove the keys, the vehicle will run for the amount its scheduled for. Default is 15 minutes.
"dont ground out!"
awesome_elec
Posted: February 20, 2010 at 5:40 PM / IP Logged
Is it possible to do this on a manual transmission?
tedmond
Gold - Posts: 4,610
Posted: February 20, 2010 at 7:18 PM / IP Logged
yes it is.
the only i do not like about the compustar pit stop mode, it takes a few seconds for the unit to power the ignition wires. its not instant like some other units.  But overall a great unit.
Ted
Compustar Expert
mikvot
Gold - Posts: 1,043
Posted: February 20, 2010 at 7:58 PM / IP Logged
Yep, Tedmond...I'm with you on that. If you pull the key too soon, you end up with a very confused vehicle. Sort of a pain in the butt, but I still love my Star.
tedmond
Gold - Posts: 4,610
Posted: February 20, 2010 at 8:05 PM / IP Logged
lol i have done that before. i hear the siren chirp, yank my key, the car dies then you see ignition power back on and relays click.
i love the compustar, but just the delay between starts/pit stop is a minor issue. bulletproof unit as always.
Ted
Compustar Expert
jaymicas
Posted: January 21, 2011 at 1:03 PM / IP Logged
So, how do you get it into stop and go mode with a manual transmission?  Same steps?  I talked to my dealer, and they said that it has to be put into reservation mode first before the remote start can take control back, so therefore you need to let the engine stop then arm then restart it again with remote start.
kohara73
Copper - Posts: 192
Posted: January 21, 2011 at 4:32 PM / IP Logged
The start of reservation mode on a manual is more or less a pit stop mode. Same procedure, you activate R/S while engine running, the remove key and the vehicle stays running. On my Prostart if I press lock after the doors are closed, it will lock and shut down. But if I press trunk after shutting the doors, it will lock the doors and start the 15 min. run time. I'm sure most other units will have a way of doing this.
Keith
