100 amp draw, will this work?
eaglemanrus
Posted: November 27, 2009 at 7:03 PM / IP Logged
I have a Mobile Linear amp that draws 100 amps on key-down.  Im going to run it inside the house. I have a 935 amp deep cycle battery connected to a 52 amp power supply thats connected to the screws on the battery.  The amp is connected to the post on the battery.  When I key down, I will be pulling from the battery 100 amps for the short time period of key down. Will this system work for me with the 12 volt 52 amp power supply or will I need another method in keeping the battery charged up?   Any advice will be appreciated...  Dave
"Eagle View Ranch" in Arizona
Platinum - Posts: 13,717
Posted: November 27, 2009 at 7:55 PM / IP Logged
It should be OK for short transmissions with breaks in between.  But you will have to connect it and see how it holds up.
eaglemanrus
Posted: November 27, 2009 at 8:30 PM / IP Logged
OK,  THANKS!    I just about have everything together now, planning on setting the system up this weekend, will let you know how it works.....  Thank You!   Dave
Thursday, July 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
