05 sorento tach wire location?
Ron_toolman
Member - Posts: 32
Posted: November 30, 2009 at 9:25 PM / IP Logged
Hi .. trying to locate a good tach source wire on a 05 Sorento, the diagram says the typical place a coil pack, but when you remove the plastic shield covering the motor what a surprise no sign of any coil or plug wires, they are buried under covers which would take hrs. to remove. I've installed the tach wire at the cluster - 28 pin plug at pin 5 GREEN/ Blk ... but can't get remote starter to learn it, tried both ways as indicated in the book. Any help would be appreciated.
Thanks Ron.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 03, 2009 at 10:56 PM / IP Logged
Its at the ECM, or behind the cluster.....same color. GREEN/ .black.
ECM is under the foot area on the pass. side.
Ron_toolman
Member - Posts: 32
Posted: December 04, 2009 at 7:47 AM / IP Logged
Thanks for your reply ...... can you tell me which plug, I have it on plug 24 pin, pin 5 GREEN/ blk now but not working. They (Prostart) say volts should be under 4 volts. I don;t know for sure if they mean at that wire or at the Injector wire they said to use as an alternate. I can't find anything on this vehicle.
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
