08 magnum remote start diagram
Xlr8
Member - Posts: 9
Posted: December 02, 2009 at 11:12 AM / IP Logged
Looking for r/s diagram for 08 magnum. nothing comes up in the search, and the autostart tech support has a half the diagram missing.
Any help would be great!!
Platinum - Posts: 13,725
Posted: December 03, 2009 at 2:03 PM / IP Logged
I will post the info you  asked about later today.  Food for thought until then.
http://www.bypassevolution.com/evo-chr_video.html
Xlr8
Member - Posts: 9
Posted: December 03, 2009 at 2:49 PM / IP Logged
Thanks man!!
I tried it last night with an idatalink and a automobility diagram with no luck 08 magnum remote start diagram - Last Post -- posted image.
any help would be great
Posted: December 03, 2009 at 3:51 PM / IP Logged
This is for the 6,1 Litre  There are several notes for both models. Do you have this engine or the 5,7
08 magnum remote start diagram - Last Post -- posted image.BatteryLIGHT BLUE/RED(+)IGNITION SWITCH HARNESS
08 magnum remote start diagram - Last Post -- posted image.Ignition 1PINK/WHITE(+)IGNITION SWITCH HARNESS
08 magnum remote start diagram - Last Post -- posted image.Accessory 108 magnum remote start diagram - Last Post -- posted image.
08 magnum remote start diagram - Last Post -- posted image.Starter 1YELLOW/GRAY(+)AT TIPM MODULE BEHIND RIGHT HEADLAMP UNDER HOOD08 magnum remote start diagram - Last Post -- posted image.
08 magnum remote start diagram - Last Post -- posted image.Starter 208 magnum remote start diagram - Last Post -- posted image.
08 magnum remote start diagram - Last Post -- posted image.Anti-Theft TypeDAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
08 magnum remote start diagram - Last Post -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
08 magnum remote start diagram - Last Post -- posted image.Key SensePINK/LIGHT BLUE(-)IGNITION SWITCH HARNESS
08 magnum remote start diagram - Last Post -- posted image.Speed SenseDARK GREEN/ BROWN(AC)AT PCM MODULE ON PASSENGER FENDER UNDER HOOD
08 magnum remote start diagram - Last Post -- posted image.Parking Lights08 magnum remote start diagram - Last Post -- posted image.
08 magnum remote start diagram - Last Post -- posted image.Low Crr. Pk LightsWHITE/ BROWN(-)AT VEHICLE HEADLIGHT SWITCH08 magnum remote start diagram - Last Post -- posted image.
08 magnum remote start diagram - Last Post -- posted image.Brake LightsGREEN / WHITE(+)AT SWITCH ABOVE BRAKE PEDAL
08 magnum remote start diagram - Last Post -- posted image.Reverse LightsWHITE/ LIGHT GREEN(+)IN HARNESS IN PASSENGER KICKPANEL
08 magnum remote start diagram - Last Post -- posted image.HornDARK GREEN/ ORANGE(+)IN HARNESS AT VEHICLE HORN08 magnum remote start diagram - Last Post -- posted image.
08 magnum remote start diagram - Last Post -- posted image.Rear DefrostDARK BLUE
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
