1995 grand cherokee, remote start/keyless
resoof
Member - Posts: 9
Posted: December 02, 2009 at 4:49 PM / IP Logged
What would be a good inexpensive remote starter with keyless entry for a 1995 Jeep grand cherokee?
Posted: December 02, 2009 at 5:12 PM / IP Logged
Good and inexpensive are mutually exclusive
resoof
Member - Posts: 9
Posted: December 02, 2009 at 5:32 PM / IP Logged
i just need one that will work. 1 way and does not have to cover long distances. keyless entry would be nice but not necessary, no alarm needed.
Posted: December 02, 2009 at 5:35 PM / IP Logged
Viper, Hornet, Compustar, etc all make very good entry level product.
tommy...
Gold - Posts: 1,901
Posted: December 02, 2009 at 6:38 PM / IP Logged
Most units come with keyless built in...Although there has been a growing trend for 1 button start only's...Which usually has an unlock output...Howies suggestions are good solid products...Few more...Ultra Start...Auto-Page...Code...Any of these six suggestions should work...Does the 95 cherokee need a module for doorlocks...? Maybe it was 96 and up...Anyhow...You are installing it...?   My suggestion is to hook up tach...! And make sure crank time is sufficient...Dont forget factory alarm dis-arm...! Again keyless is pretty standard...And the units mentioned usually "work" just fine...As long as the install is done properly...Some model #'s from Code are the CA-5050...CA-6150...CA-6550
http://mobile.audiovox.com/audiovox/AudiovoxController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_CODEALARM
M.E.C.P & First-Class
