voltage
thatdude06
Posted: December 04, 2009 at 10:21 AM / IP Logged
 my new setup is going to be 2 alpine type r 12's the d2 versions on a sundown 1200d
this is going to be wired at .5 ohms daily
need to know what kind of voltage and wire i should use
im thinking of  having  2 kinetic 600's with 1/0 guage will that hold it though i dont wanna blow my amp
can someone help
thatdude06
Posted: December 04, 2009 at 10:22 AM / IP Logged
2006 nissan altima
t&t tech
Platinum - Posts: 2,622
Posted: December 04, 2009 at 5:48 PM / IP Logged
1) OK great!
2) One question is your amp half ohm stable?
3) Well i saw altima so i know it's a car, so i'm guessing twelve volts or there about! LOL
4) Amount of batteries and size of power wire is way overkill, i'm no expert, and i can tell  you this!  Four gauge will be fine!
tommy...
Gold - Posts: 1,901
Posted: December 05, 2009 at 6:06 PM / IP Logged
And then check the wires under your hood...(the big 3)...Maybe he listens to the system with the car OFF alot...!? What kind of box are they going into(size)...? "My power wire is bigger then yours"...!
M.E.C.P & First-Class
Posted: January 05, 2010 at 8:56 AM / IP Logged
Ref the power wire; bet the main battery feed is about 4 gauge, so why 1 gauge amp cable? Violation of 2nd law of thermodynamics, or you can't get out more than you put in!
Are you aiming to hit the space station? You will if you run those amps on 1/2 ohm.
Personally, I'd run a split charging system with a deep cycle battery in the rear.
t&t tech
Posted: January 05, 2010 at 6:03 PM / IP Logged
Guy abandoned this post it seems!
Posted: January 05, 2010 at 6:14 PM / IP Logged
Shocking
t&t tech
Posted: January 06, 2010 at 7:06 PM / IP Logged
Are you trying to be sarcastic howard?voltage - Last Post -- posted image.
