2010 kia soul bypass
bruc007
Copper - Posts: 74
Posted: December 07, 2009 at 5:39 PM / IP Logged
Hi I am using a tb-350 and a key to bypass the transponder.The remote works ok with the key in the ignition ,however it wont work with the bypass hooked up.The key for the box is tested ok.this bypass also says if the ring has two wires ,which it does you can cut one and cut the loop of the antenna ring and hardwire it.Anyone done this?It also has settings for different coil windings?? does it need keysense to be initiated?
mustyk@att.net
Copper - Posts: 132
Posted: December 15, 2009 at 9:22 PM / IP Logged
key sense wire may need to be grounded to initiate bypass
thetopinstaller
