03 dodge ram ignition harness
bowtorc
Member - Posts: 14
Posted: December 17, 2009 at 9:35 PM / IP Logged
Can anyone tell me the source for the pink/black wire in the ignition harness at the steering colum? I have lost the power there and have not been able to find a fuse so I am looking for the connection point on the supply end
roger
Platinum - Posts: 13,725
Posted: December 17, 2009 at 10:04 PM / IP Logged
is it the battery wire, or acc or Ignition?
bowtorc
Member - Posts: 14
Posted: December 17, 2009 at 10:15 PM / IP Logged
  Its the constant 12 volt that I am hooking the remote starte to at the harness under the steering colum
roger
yimke
Copper - Posts: 417
Posted: December 18, 2009 at 10:27 AM / IP Logged
*facepalm*
Check your BIG fuses in the fusebox, if not a connector link from the battery. Then take it to a shop to finish the job.
bowtorc
Member - Posts: 14
Posted: December 18, 2009 at 10:09 PM / IP Logged
  Gee, I'm sorry I thought the forum was to help all learn something not to chide someone for doing it themselves. I assume that you will take all of your problems to a shop as well. There is no need for the forum if that is the answer since you either know it all or take it to a shop
roger
bowtorc
Member - Posts: 14
Posted: December 20, 2009 at 8:25 PM / IP Logged
  It was a broken wire under the fuse box. Looks like something from the road hit it and the bottom of the battery box.
roger
