2001 honda accord, idatalink
lake207
Member - Posts: 16
Posted: December 25, 2009 at 1:16 AM / IP Logged
i have 2001 Honda accord from Canada, and i am trying to install IDATALINK ADS-TB-HA the diagram said pink wire from IDATALINK go to pin5 green wire but there is no green wire pin 5 do not have any wire. i did find blue and red wire but no green wire.plzzzz can anybody help me!!!!
http://www.idatalink.com/search/index/model/721
tedmond
Gold - Posts: 4,610
Posted: December 25, 2009 at 8:23 AM / IP Logged
your reading it wrong.
Data is RED pin 2
Synchro is BLUE pin 3
btw pink comming off the ADS is connected to ignition at key barrel. Ignition is YELLOW/BLACK pin 1
these wires are found in a 5 pin CONNECTOR that is GREEN @ the key barrel.
Ted
Compustar Expert
lake207
Member - Posts: 16
Posted: December 25, 2009 at 10:09 AM / IP Logged
how do i program it?
tedmond
Gold - Posts: 4,610
Posted: December 25, 2009 at 1:00 PM / IP Logged
i assume your running it w2w and not d2d?
if so just plug in the 3pin wiring plug, press and release program button for either method you choose. 1 falsh is for d2d and 2 flashes for w2w.
i am reviewing this from memory, so i might be off but you have the insatllation manual, so you should look it up.
1) Place key in ignition barrel only. plug in connectors and hold programming button until led stays on
2) Turn key to IGNITION (2 clicks)
3) LED will turn off, wait as it will turn back on  solid for 4 seconds or so
4) LED turns off, remove key and try to remote start
Ted
Compustar Expert
lake207
Member - Posts: 16
Posted: December 25, 2009 at 9:09 PM / IP Logged
i did install all of the wires as it show in the diagram but no luck.this car is from Canada i don't know if that make any different?
tedmond
Gold - Posts: 4,610
Posted: December 25, 2009 at 9:45 PM / IP Logged
no differance here. the wires are the same colour in the NA regions. Whats the problem your having? not being able to program it or not being able to wire it up properly?
Ted
Compustar Expert
lake207
Member - Posts: 16
Posted: December 25, 2009 at 10:33 PM / IP Logged
hey thank you very much for helping me i really appreciate that. and yes did got it working.but now i need to know what color is rear Defroster Output wire?? and were is located at??? according to my diagram shows a BROWN / yellow at the switch.
tedmond
Gold - Posts: 4,610
Posted: December 26, 2009 at 7:04 AM / IP Logged
i have it as BROWN / yellow (-) latched trigger @ switch. what you want to do is take the status output or ground when running from your alarm/rs, and wire it up to a relay just incase it draws more than 250mA.
85 - ground when running (status output)
86 - constant 12v
87 - high current ground ie chassis
30 - to BROWN / yellow defrost wire @ switch.
Ted
Compustar Expert
