ford explorer headlight stereo dimmer
andycr
Posted: December 26, 2009 at 10:53 PM / IP Logged
I have a 1993 Ford Explorer which I just took to Car Toys to get a JVC KD-AHD59 installed in. Everything works fine (except that I seem to have a blown speaker, but that's a separate issue), but the lights of the stereo are supposed to dim when you turn on the headlights. It doesn't, and it's very bright and distracting at night. I can turn the dimming on and off manually, but it would be nice if it worked. I notice from a pinout of the car that the switch does indeed have a pin to the stereo, and the stereo has a pin to accept it. Did they just fail to hook it up? What do I tell them to get them to fix it? If they won't, can I do it myself?
Thanks!
Platinum - Posts: 13,726
Posted: December 26, 2009 at 11:27 PM / IP Logged
ford explorer headlight stereo dimmer - Last Post -- posted image.BatteryLIGHT GREEN/ YELLOW(+)RADIO HARNESS
ford explorer headlight stereo dimmer - Last Post -- posted image.AccesoryYELLOW/BLACK(+)RADIO HARNESS
ford explorer headlight stereo dimmer - Last Post -- posted image.GroundBLACK(-)RADIO HARNESS
ford explorer headlight stereo dimmer - Last Post -- posted image.IlluminationORANGE / BLACK(+)RADIO HARNESS
ford explorer headlight stereo dimmer - Last Post -- posted image.DimmerLIGHT BLUE/RED(+)RADIO HARNESS
ford explorer headlight stereo dimmer - Last Post -- posted image.Amp Turn OnDARK BLUE(+)RADIO HARNESS
andycr
Posted: December 28, 2009 at 5:50 PM / IP Logged
Thanks. I don't think I'll have Car Toys do things for me from now on...
Car Toys Manager (Chad): "We'll do it for free if you want. We didn't connect it because it might blow a fuse." (??)
Me: "I'll try it and see."
Chad: "Actually, your stereo doesn't have a dimmer wire."
Me: "Yes, it does. It's orange and white striped."
Then he tried to sell me a $500 amp...
Posted: December 28, 2009 at 6:26 PM / IP Logged
Did they get the dimmer wire connected?  Is it working properly now?
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
