wiring 2 new subs
paolotonzini
Posted: December 31, 2009 at 9:53 PM / IP Logged
i just got 2 boston acustic g3 10in speakers and a ROCKFORD T500-1BD 1000W amp, i want to wire the subs up so the amp sees a 1 ohm load to get the most out the amp and that way each sub gets aprox 250 rms, is this possabe with dual 4 ohm voice coils im seeing alot of differnt info out there, any help would be apricated thanks
paolotonzini@yahoo.com
Platinum - Posts: 13,726
Posted: December 31, 2009 at 10:22 PM / IP Logged
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono
wiring 2 new subs - Last Post -- posted image.
paolotonzini
Posted: January 01, 2010 at 3:41 AM / IP Logged
so if the 2 subs are in the box should i run a positive leg n split it out side the box n send one to one speaker and the other to the other speaker? or does the positive have to go through the one speker and continue to the next? because in me box witch is ported, it has two seprate compartments so i would have to split the positve out side the box or drill a small hole inside the box to send the wire through to the other side, im just trying to be shure because i already burned out a channel on my rockford 800a2 and one of my kicker comp vr's so im trying to figure this out n do it right, thanks alot
Posted: January 01, 2010 at 6:23 AM / IP Logged
Do this twice.
Option 1 (parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono
paolotonzini
Posted: January 04, 2010 at 6:20 PM / IP Logged
ok so then each speeker wired that way then conect each sepritly to the amps two speeker inputs then will be one ohm?
Posted: January 04, 2010 at 7:47 PM / IP Logged
yes.
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
