memphis shallow mounts in suv
isa-kuruption
Member - Posts: 18
Posted: December 31, 2009 at 10:20 PM / IP Logged
I just bought an Expedition, and I am considering building a subwoofer enclosure in the inside rear quarter panels in the back in order to save the cargo space (so, pull panels, fiberglass up an enclosure, etc etc). I already have a Zapco 9.0 that came out of my former car, so I'm looking at pushing 2000 watts when I turn it up (yes, I know of the electrical requirements, etc).
So the idea was to install two of the 12" Memphis shallow mounts on either side facing directly across. I am afraid that frequency cancellation will take place.
Any thoughts? If I need to, I guess I could angle the subs to the rear a bit more. Also, anyone done this?
Also, anyone know what the recommended enclosure size is for these subs? I can't find anything online.
Thanks.
Platinum - Posts: 13,726
Posted: December 31, 2009 at 10:27 PM / IP Logged
The only time I would use any shallow mount sub would be in a standard cab pickup truck.  If you have room for a conventional sub, use one.
isa-kuruption
Member - Posts: 18
Posted: December 31, 2009 at 10:34 PM / IP Logged
That's a possibility, but even so, the question about cancellation still remains. :)
Posted: December 31, 2009 at 10:48 PM / IP Logged
I do not remember the math required, but I do not think there will be a problem.  Looking for the math and will get back to you.
What would be the distance between the 2 speakers?  Any idea of the altitude where you are located?
Nevermind, at  sea level a 45Hz waveform is 25 feet in length.  There will be no noticeable cancellation.
isa-kuruption
Member - Posts: 18
Posted: December 31, 2009 at 10:55 PM / IP Logged
4-5 ft across and sealevel. ;)
Posted: December 31, 2009 at 11:00 PM / IP Logged
Ithere will be no problems with cancellation.  At sea level a 45Hz waveform is 25 feet in length.  Both speakers will be relatively the same distance from your spot.
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
