zx300.1
qwikcharger
Posted: January 04, 2010 at 9:15 PM / IP Logged
i have a kicker zx300.1 amp that was working in my old truck. got a new truck (the dodge) and now it won't work. when the truck is off i have +12 vdc at the power input. when i start the truck the input power drops to +6 vdc and the remote wire is +6 vdc as well. when the remote wire is out of the amp and the truck running the remote wire reads +12 vdc. any ideas??? btw all fuses in the amp and on my constant +12 vdc from battery are all good.
06 Dodge Ram Quad Cab
Pioneer AVIC-N3
Kicker ZX300.1
Kicker ZX650.4
j.reed
Copper - Posts: 716
Posted: January 04, 2010 at 9:35 PM / IP Logged
What is your remote line hooked to? Is it hooked to an after market deck or a key hot?
zx300.1 - Last Post -- posted image.
qwikcharger
Posted: January 04, 2010 at 9:42 PM / IP Logged
sorry, the remote turn on is hooked up to the remote on the HU (pioneer avnc-n3)
Pioneer AVIC-N3
Kicker ZX300.1
Kicker ZX650.4
Platinum - Posts: 13,726
Posted: January 04, 2010 at 10:14 PM / IP Logged
Check the ground connection at both ends of your amplifier's ground wire.  If that is good, move your ground to a different piece of the vehicle.
qwikcharger
Posted: January 05, 2010 at 6:08 AM / IP Logged
thanx i will try that after work today. cause now my zx650.4 is doing the same thing. also can i use a distrobution block on my grounds for the amps or would i be better off running two seperate grounds???
Pioneer AVIC-N3
Kicker ZX300.1
Kicker ZX650.4
qwikcharger
Posted: January 05, 2010 at 7:58 PM / IP Logged
bad ground. the wire had seperated from the ring that i put on it. thanx for all the input.
Pioneer AVIC-N3
Kicker ZX300.1
Kicker ZX650.4
Posted: January 05, 2010 at 11:06 PM / IP Logged
In my opinion, the best ground is the shortest possible ground.  There is no way to have both grounds as short as possible if they go through a distribution block.
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
