2008 dodge ram remote start
cmwade
Member - Posts: 8
Posted: January 08, 2010 at 10:14 AM / IP Logged
It was the BLACK/ white neutral safety wire from the RS that I was missing. They show it wired a couple of ways, not sure which way is correct for my 08 Dodge Ram. As long as that wire is resting at ground, it fires right up every time. Any suggestions on which is the correct way to wire that on this vehicle? Not sure why that wire needs a switch...if the truck has a factory starter interrup for anything other than Park or Neutral, can it just be wired to ground? What is the function of the switch? The last RS I did (a very basic Avital several years back) had a "valet override" switch that basically let you deactivate the RS system via that switch. Is this the same function now?
05gt
Silver - Posts: 628
Posted: January 08, 2010 at 6:25 PM / IP Logged
if your truck is an automatic all you have to do is ground that wire
the purpose for the switch is if you don't want the remote start activated all you have to do is flip the switch to off, like if you were giving your truck to a mechanic or something, when you want to activate it again just flip the switch to on
cmwade
Member - Posts: 8
Posted: January 08, 2010 at 8:25 PM / IP Logged
Kinda what I figured, that I could just ground that wire...I installed the switch anyway and will use it for "valet mode". All safety checks complete, RS is working reliably, only things left are parking light output and rear defrost output. Those can wait until spring - it was about 2 degrees above zero today and the Mega Cab won't fit in the garage with the door closed so I'm done for now. At least I don't have to go outside to start it anymore!
Thanks to all for your help!
05gt
Silver - Posts: 628
Posted: January 08, 2010 at 11:11 PM / IP Logged
you have two options for parklights, negative or positive
the negative system is through a resistor with a value of about 1.1kohms and a relay would also be needed
the positive is 1 wire for left and 1 wire for right, relays would be needed
for rear defrost is a positive (latched system) probably about 7 or 8 mins
