5901 in 97 civic
bmorei9s06
Member - Posts: 12
Posted: January 11, 2010 at 10:36 PM / IP Logged
hey guys. im looking at the install guide for the 5901 i got and im trying to match the wires up so i can install this easily and cut what wires i wont need. on the main harness(h1) i believe i will be cutting, the RED / white (-)200ma aux/trunk output, WHITE/ brown parking light isolation wire, purple (+) door trigger, BLACK/ white dome light supervision. on h2 harness ill be taking out all the aux outputs since i dont have any aux right now to install and the oem arm/disarm wires. in the same harness, theres all these (-)200mA wires such as, status output, accessory output, starter output, and ignition output. those all be cut as well? also the brake shutdown will go to GREEN / WHITE wile on brake pedal? what about the neutral safety input? i pretty much have the h3(remote start) harness figured out. im putting this in my cx hatch so i got door actuators for power locks. will i need a relay or just wire them up to the alarm since theres a door lock connector? if you could help me, i know its through a post but all i could find was a basic wiring diagram. but id appreciate whatever help you could assist me in. thanks.
precisionmobile
Posted: January 11, 2010 at 10:58 PM / IP Logged
I do these cars all day. Not that hard. You can get the parking brake and tach wire right behind the cluster. Tach is a solid blue wire and parking brake is GREEN/ red. Please test the brake wire as there is 4 of that color back there. All you have to do is run the tach wire from the alarm and the netural saftey switch which goes to the parking brake there. It will be the black with white stripe wire. Also I am giving you instructions on a 5 speed. Also make sure you plug in the remote start switch.
For your parking brake do this. The brake switch is a pia to get to. Grab that wire in the driver kick panel in the harness that runs to the back. Its a thick green with white stripe.
precisionmobile
Posted: January 11, 2010 at 11:00 PM / IP Logged
Here is also a good site on how to do a stealth install on your car. www.honda-tech.com Look in the a/s/v in there fourm. Your car is a hot ticket.
t&t tech
Platinum - Posts: 2,622
Posted: January 12, 2010 at 2:41 PM / IP Logged
It's easy as pie on that car! If the car is manual then connect as said above, if it's tranny then, just ground the wire, there is a toggle switch that must be plugged on for it to function anyway!
bmorei9s06
Member - Posts: 12
Posted: January 12, 2010 at 10:27 PM / IP Logged
thanks man. remote start switch though? is that the little switch that comes with the alarm correct? also im a little confused on the starter kill. i read this "The blue/white (-) 200mA 2nd status/rear defogger output of 5 pin connector or the blue (-) 200mA status output must be connected to the BLACK/ blue lead of the CIS, [clutch interlock switch., or connect the H3/4 violet, starter output, after the cars starter/starter cut relay, it will be a BLACK/ red lead at the relay." and go confused. where should the green and purple wire for starter kill go?
t&t tech
Posted: January 13, 2010 at 12:10 PM / IP Logged
Cut the starter wire in half, and connect the green to key side and the violet to the side leading to the engine bay!
t&t tech
Posted: January 13, 2010 at 12:11 PM / IP Logged
Yes when i say switch i'm reffering to the plug in togle switch that came withthe alarm!
bmorei9s06
Member - Posts: 12
Posted: January 13, 2010 at 3:59 PM / IP Logged
ahhhhh ok. gotcha now! thanks!!
bmorei9s06
Member - Posts: 12
Posted: January 13, 2010 at 4:02 PM / IP Logged
oh and also with the keyless entry. i know the alarm has the output wires. do i need a relay or just hook them right to the aftermarket door actuators?
