car audio wiring
arisk
Posted: January 15, 2010 at 8:15 AM / IP Logged
Hi there,
Is the ACC wire the same with +12 Ignition wire?
Can you connect the Ground wire (black) on the negative pole of the battery?
I cannot identify two wires on my Toyota Corolla Spacio 2003 the one is brown with silver dots and the other one id green with brown dots, does anybody know?
oldspark
Gold - Posts: 4,913
Posted: January 17, 2010 at 2:55 AM / IP Logged
The ACC is off during cranking. IGN is on during cranking.
Ground can go to batt-. (Sometimes to engine block if max SPL during charging is sought.)
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
