avistart 4103
chev104275
Gold - Posts: 1,436
Posted: January 17, 2010 at 8:14 PM / IP Logged
you may be able to get away with just using the 2 ing 1 acc but i power up everything at the ing harness just try to avoid problems
as far as the bitwriter as i said in a previous post you don't need the bitwriter but it does make it a little easier
c_frank2
Member - Posts: 13
Posted: January 17, 2010 at 8:40 PM / IP Logged
I found out about a dei 451m module instead of using relays, i just ordered one. Did i need two of those modules or would one module work in place of the two relays?
Thack79
Silver - Posts: 526
Posted: January 19, 2010 at 7:55 AM / IP Logged
one will work in place of two relays. instructions are on the back of the 451
c_frank2
Member - Posts: 13
Posted: January 21, 2010 at 4:56 PM / IP Logged
are there any factory relays in place for the powers locks that i need to do anything with or should i just install the dei module?
c_frank2
Member - Posts: 13
Posted: January 21, 2010 at 9:38 PM / IP Logged
Also, how would i wire up the relay for the second ignition wire? I have searched the forums and found nothing on that.
