2000 ford taurus stereo wiring
abower911
Posted: January 20, 2010 at 1:43 PM / IP Logged
I have a wiring harness for it but it runs from the trunk, was wondering if someone had the diagram for the factory wiring to save some time running all this wire from the trunk.
91stt
Silver - Posts: 564
Posted: January 20, 2010 at 2:54 PM / IP Logged
It will probably be easier for you to use the harness since you need to go back there to pick the rear speakers anyway.
joch1314
Copper - Posts: 301
Posted: January 20, 2010 at 2:59 PM / IP Logged
it takes about 5 mins to run it from the trunk, and the only tool you really need is a panel popper.  no need to remove any panels, but you'll use the popper to tuck the wires under the panels on the driver's side.  also, if you have the harness, it should come with the antenna extension and adapter.  not all that difficult to do, if you just give it a shot.
...half of the truth can be worse than a lie. <----Roger Russell said that..
