2007 honda accord immobilizer
spencer1218
Posted: January 20, 2010 at 5:34 PM / IP Logged
Installing a remote start car alarm in my 2007 Honda Accord SE using a 556 unit. Car wont remote start or start with the original key. Unhooked alarm and car immobilizer still wont let car start, Help please, any ideas?
Spencer
Chris Luongo
Platinum - Posts: 3,746
Posted: January 20, 2010 at 6:20 PM / IP Logged
Won't start even with the key?
Does the starter crank?
What is the green "key" symbol on the dashboard doing when you try to start?
dman007
Copper - Posts: 106
Posted: January 20, 2010 at 6:21 PM / IP Logged
I would try to disconnect the battery for 15 mins, reconnect then try again with key.  Please rememeber to disconnect all bypass wires, including ring.
Id also double check to see if you pulled out any harnesses by accident. Namely the factory immobilizer wires.
DTS Performance
St Petersburg, FL
dkouri80
Member - Posts: 8
Posted: January 20, 2010 at 6:35 PM / IP Logged
I know this may sound stupid. Did you check fuses? I didnt look at any of the notes on this car but did you have to cut any wires for the bypass install. I blew a fuse when I did a PK3 plus when I cut the wire for it. Hope you get it. Good Luck.
kgerry
Platinum - Posts: 3,455
Posted: January 21, 2010 at 10:58 AM / IP Logged
did you cut the starter wire when installing the alarm portion??
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
