2009 mitsibushi eclipse bypass?
eksessiv audio
Member - Posts: 16
Posted: January 22, 2010 at 2:19 PM / IP Logged
Other then relinguishing a key, is there another PATS module out there....  I have some Autopage Mitsibushi 1 & 2 PATS Modules that might work, I am not sure... They are listed up to 06 Models????
kickyride
Copper - Posts: 100
Posted: January 22, 2010 at 3:38 PM / IP Logged
I'm pretty sure you'll have to do the "key in a box" solution. The problem is that most Mitsubishi's can't have a key added without a scan tool. And, a lot of dealers will refuse to program an aftermarket bypass kit for you. So, this make an aftermarket solution not very viable. So, ultimately, giving up a key is the path of least resistance (if you can live without a spare key).
Mike
Mike
Sales/Tech Support - KICKYRIDEoCOM mobile electronics
MECP 1st class-Security Specialist
eksessiv audio
Member - Posts: 16
Posted: January 22, 2010 at 5:46 PM / IP Logged
I use Idatalink, but have some older MITSIBUSHI 1 & 2 PATS Modules that lets you do that just like the Ford Modules... Need 2 keys to program them...  I looked on the internet and said the Mitsibushi 1 PATS will do Eclipse .
Chris Luongo
Platinum - Posts: 3,746
Posted: January 22, 2010 at 5:48 PM / IP Logged
I just did my own programming on a 2010 Lancer. It's in the owner's manual for the car. Only the Canadian cars require the dealer scan tool. You do, however, need two functioning keys.
Those "Autopage" modules must surely be just rebadged Fortin pieces, as they're the only company that makes Mitsubishi bypasses.
Go to www.ifar.ca and put in what kind of car you have....I'm almost sure it's the PATS-MITSUBISHI-2 that you need.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
