dual xdvd9101
autoapp
Member - Posts: 21
Posted: January 25, 2010 at 10:33 AM / IP Logged
A customer brought in a flipout Dual XDVD9109 with the wrong harness. So i called Dual and asked for the harness wiring diagram they said they would not be able to give me that information. It is a sixteen pin harness that has a set of RCA jacks coming out of the bottom row. I know its the wrong harness cuz there would not be a set of RCAs coming out of the power harness cuz they come from the back of the deck and are not removable. Can anyone give me the wire colors for the sixteen pin harness? Please!
joch1314
Copper - Posts: 301
Posted: January 25, 2010 at 12:30 PM / IP Logged
Some DUAL harnesses DO have a set of RCA's coming out of the power harness.  if i'm not mistaking it's the gray rca's that are attached with the power harness (rear output).  Have you even tried using that harness?
...half of the truth can be worse than a lie. <----Roger Russell said that..
autoapp
Member - Posts: 21
Posted: January 25, 2010 at 2:29 PM / IP Logged
no,i havent. but all the RCA wiring is there on the backof the deck. Front, Rear, Subwoofer, Video/Audio in, Ant., There is supposed to be a BROWN / white (rev. wire) and a yellow/blue (park brake) It says it right on the deck. Those wires are nowhere to be found. "Usually" the yellow/blue is located with the RCA's and Ant. jacks come out of the back of the deck. As well the BROWN / white comes from the 16 pin harness, "Usually".
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
