gm passlock2 bypass
dasbogie
Silver - Posts: 514
Posted: February 02, 2010 at 7:07 PM / IP Logged
I got the diagram for the 2 relays and resistor to bypass passlock 2 from the downloads section of this site and it worked perfect.  It has a diode on the gwr or status wire to the relay.  I check audiovox website and their's  is a tad different but same idea.  They do not have diodes on the gwr/status wire triggering the relays.  Would going by the avox diagram set you up for some feedback without the diode(s)?
tedmond
Gold - Posts: 4,610
Posted: February 03, 2010 at 7:41 AM / IP Logged
diodes prevent feedback.
if you have them on a relay coil, that prevents voltage spiking that can damage the alarms (-) output. Its good to use diodes as a preventative meansure, but the diagrams are the same. the alarms outputs nowadays have durface mount diodes to prevent backfeed onto the unit itself. so no need to worry.
Ted
Compustar Expert
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
