2006 lexus lx470 parking lights wire?
shadowinfector
Copper - Posts: 199
Posted: February 04, 2010 at 2:18 PM / IP Logged
2006 Lexus LX470 Parking Lights Wire???
I tested almost all the wires in the fuse box and cant locate the parking lights wire.....does anyone know if I can just wire it straight to one of the wires running into the actual parking lights?? or an alternate location?
chev104275
Gold - Posts: 1,436
Posted: February 04, 2010 at 2:33 PM / IP Logged
Parking Lights GREEN (+) AT THE BACK OF PARKING LIGHT UNDER HOOD
Low Crr Pk Lights RED / YELLOW (-) LIGHT SWITCH HARNESS
PARKING LIGHTS ( - ) GREEN/ BLACK (-)   @ ECU, 26-Pin Plug, Pin 8, See NOTE *2
PARKING LIGHTS ( + ) GREEN (+)   @ ECU, 30-Pin Plug, Pin 28, See NOTE *2
NOTE *2 THE ECU (ELECTRONIC CONTROL MODULE) IS ATTACHED TO THE BACK OF THE FUSEBOX IN THE DRIVERS KICK PANEL.
ive never done this truck but one of these should work for you
tedmond
Gold - Posts: 4,610
Posted: February 04, 2010 at 5:05 PM / IP Logged
you can always get it at the light switch harness. just test.
Ted
Compustar Expert
tedmond
Gold - Posts: 4,610
Posted: February 04, 2010 at 7:32 PM / IP Logged
Parking Lamp GREEN (+) AT BODY ECU PIN 28 OF 30 PIN PLUG*
*body ECU at back of fusebox in DKP
Ted
Compustar Expert
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
