2010 toyota yaris
ranger svo
Copper - Posts: 70
Posted: February 15, 2010 at 6:23 PM / IP Logged
I just bought a new Toyota Yaris and I was wondering if anyone had wiring info on this car. I wanna put an alarm system in before the sound system goes in. Any help is appreciated.
2010 Toyota Yaris 3dr
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
tedmond
Gold - Posts: 4,610
Posted: February 15, 2010 at 6:58 PM / IP Logged
Wire Info Printout   - From OMEGA
 2010 Toyota Yaris Last Update:  10/30/2009 9:31:32 AM
 Circuit  Wire Color  Location
  Constant 12 volts GRAY (15A) YELLOW (25A) IGNITION SWITCH
  Ignition 12 volts PINK (+) IGNITION SWITCH
  Starter BLACK (+) (2 COMMON WIRES) IGNITION SWITCH
  Dome Light PINK (-) DASH FUSE BOX WHITE 6 PIN CONN, PIN 2
  Driver's Front Door Pin RED (-) DASH FUSE BOX WHITE 30 PIN CONN, PIN 21
  Pass Front Door Pin BLUE (-) DASH FUSE BOX WHITE 30 PIN CONN, PIN 24
  Driver's Rear Door Pin GREEN (-) DASH FUSE BOX WHITE 30 PIN CONN, PIN 5
  Pass Rear Door Pin BLUE (-) DASH FUSE BOX WHITE 30 PIN CONN, PIN 20
  Trunk Pin LT BLUE (-) DASH FUSE BOX WHITE 30 PIN CONN, PIN 7
  Parking Lamp WHITE (-) HEADLIGHT SWITCH
  Lock BROWN (-) DRIVER KICK
  Unlock GREEN TO YELLOW (- DOUBLE PULSE)  DRIVER KICK #201
  CANBUS HIGH VIOLET (DATA) OBDII
  CANBUS LOW WHITE (DATA) OBDII
#201 Negative door lock diagram.
CLICK HERE TO SEE AVAILABLE DOORLOCK INTERFACE KITS
   Tach Signal  LT GREEN (AC)  OBDII PIN 9
  Ignition #2 GREEN (+) IGNITION SWITCH
  Ignition #3 NA
  Accessory WHITE (+) IGNITION SWITCH
  Accessory #2 NA
  Accessory #3 NA
  Starter #2 NA
  Neutral Safety NA
  Brake Light GREEN TO VIOLET (+) BRAKE SWITCH
  Parking Brake YELLOW (-) PARKING BRAKE SWITCH
  Clutch Pedal YELLOW (INPUT) BLACK (OUTPUT) (+N.O.) CLUTCH PEDAL SWITCH
  Reverse Light RED (+) DASH FUSE BOX WHITE 30 PIN CONN, PIN 30
  Rear Defrost BLACK (- LATCHED) DEFOGGER SWITCH
CLICK HERE TO SEE AVAILABLE IMMOBILIZER BYPASS KITS
Page 2
   Window Up   D\ RED, P\ WHITE, D\ YELLOW, P\ RED @ MAIN SWITCH #211
  Window Down  D/ GREEN, P/ PINK, D/ BLACK, P/ GREEN
  Keysense YELLOW (-)  IGNITION SWITCH
  Trunk Release NA
  OEM Horn BLACK (-) HORN SWITCH
  Headlights LT BLUE (-) HEADLIGHT SWITCH
  OEM Alarm Arm SAME AS LOCK WIRE
  OEM Alarm Disarm SAME AS UNLOCK WIRE
  Vehicle Speed Sense VIOLET (AC) DASH FUSE BOX WHITE 36 PIN CONN, PIN 26
#211 Reversal rest at ground window circuit.
   OEM Keyless Module  -
  Motor Lock TAN (5 WIRE) DRIVER KICK
  Motor All Unlock PINK (5 WIRE) DASH FUSE BOX WHITE 18 PIN CONN, PIN 18
  Motor Driver Unlock
  (disarm defeat) PINK (5 WIRE) DRIVER KICK
  OEM Lock Relays -
  Add On Security Type - TYPE 5 #225
#225 Type 5 keyless entry interface.
   Left Front Speaker(+)  PINK  FRONT DOORS; Size: 6 1/2
  Left Front Speaker(-) VIOLET FRONT DOORS; Size: 6 1/2
  Right Front Speaker(+) GRAY FRONT DOORS; Size: 6 1/2
  Right Front Speaker(-) YELLOW FRONT DOORS; Size: 6 1/2
  Left Rear Speaker(+) BLACK REAR DOORS; Size: 5 1/4
  Left Rear Speaker(-) YELLOW REAR DOORS; Size: 5 1/4
  Right Rear Speaker(+) RED REAR DOORS; Size: 5 1/4
  Right Rear Speaker(-) WHITE REAR DOORS; Size: 5 1/4
  TECH NOTES:
Omega R & D, Inc. disclaims any liability in connection with installation. This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
Ted
Compustar Expert
ranger svo
Copper - Posts: 70
Posted: February 15, 2010 at 8:28 PM / IP Logged
Thank you very much, your help is sincerely appreciated
Augustus de Morgan
Posted: February 16, 2010 at 2:29 AM / IP Logged
Ted, you shouldn't need individual door pin contacts, if the dome light shuts down on locking, just wire to the pink, you've already got dome supervision on unlock. I've tried that on Auris (Corolla in Europe) and Yaris 06/09 and it works. CAN alarm frankly not needed, even use 556 for by-pass.
wibley
Posted: February 17, 2010 at 3:07 PM / IP Logged
what alarm are you fitting to your car?
