issues with amp or subs, confused
low99xtreme
Posted: February 25, 2010 at 6:20 PM / IP Logged
I am having issues, subs are sounding weak and distorted when both RCAs are hooked up to the amp but if I disconnect one of the RCAs from amp then the one sub sounds wonderful and full. I have a pioneer 2 channel amp(GM-520T) and 2 Pioneer shallow mount 10" subs(TS-SW251).
j.reed
Copper - Posts: 716
Posted: February 25, 2010 at 8:00 PM / IP Logged
Does it sound better if you undo either one of the rca's? Im betting you have your subs are out of phase with each other. Simply switch the positive and negative around on one speaker.
issues with amp or subs, confused - Last Post -- posted image.
low99xtreme
Posted: February 26, 2010 at 4:21 PM / IP Logged
Thanks i will try that.
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
