2005 toyota avalon, viper 5902
samwayfd
Member - Posts: 14
Posted: March 02, 2010 at 11:36 AM / IP Logged
I saw a diagram and all for the 2006 but didn't see anything for 2005. It is a Avalon withOUT the smart key, just the regular key.   I needed to see about a diagram and what all will be needed for the 5902 installation.
Also, if possible, a diagram for a 2003 Honda Pilot, remote start and alarm install. Thanks!
Chris Luongo
Platinum - Posts: 3,746
Posted: March 02, 2010 at 4:21 PM / IP Logged
2005-up Avalons are the same; the 2006 information should work fine for your car.
As for the Pilot, have you already tried the search feature? Those cars have been discusses on here many times in great detail.
samwayfd
Member - Posts: 14
Posted: March 02, 2010 at 5:40 PM / IP Logged
Thanks alot, I'll check into it.
samwayfd
Member - Posts: 14
Posted: July 10, 2010 at 11:13 PM / IP Logged
Ok, I tried to get Best Buy to install the 5902 but they told me they couldn't touch the airbag under the steering wheel, so it looks like I'm doing this myself.
I got into it a little today and had some concerns, and just wanted some clarification.
The ignition harness has 3 much bigger wires than the others, like 3 were 12-14 gauge while the others were 18-22 gauge. All the colors matched up like the wiring information said but I have never seen the wires in an ignition harness that small, so I was worried I had the wrong connection.
Do I need to use a relay for the trunk pop?
What about the domelight supervision?
On the ignition harness, I need to tie the two starter wires into the single starter wire on the RS?
Oh, and one more question. I am using the CANMAX 400 and it will control the auto lights shutting off after the car shuts down, but the guide just says cut the wire and splice each of the two wires to corresponding ends. It never says what wire is the auto light wire. Any ideas?
Thanks guys!
Mike M2
Platinum - Posts: 2,652
Posted: July 12, 2010 at 2:15 PM / IP Logged
The thin wires are the correct ones. Toyota has a habit of using heavy and small guage wires at the switch. Do NOT connect the 2 stater wires together. You just use a relay for the second starter. Failure to do this will eventually cause the AM1 fuse to blow.
Without looking it up, i believe the trunk pop is a negative pulse if i remember correctly. No relay is needed for this.
For domelight supervision, you will need a relay.
The autolight wire is located at the light switch. I think it's the 3rd wire from the left(but i may not be right). Simply meter this wire, it will show ground in the on position only.
Mike M2
Tech Manager
CS Dealer Services
samwayfd
Member - Posts: 14
Posted: July 12, 2010 at 8:40 PM / IP Logged
Thanks for all the help guys, it took two days (on and off)but I finally got it all together and it works great. This alarm is VERY nice.
Thanks again!
samwayfd
Member - Posts: 14
Thanks again!
valliyappan
Posted: January 14, 2011 at 8:05 AM / IP Logged
Thanks guys!
Did you find this wire? If so where and what color? I am doing an install on a corolla and using the canmax.
