viper 5701 build in relays?
mike08401
Member - Posts: 33
Posted: March 04, 2010 at 7:45 AM / IP Logged
I'm confused when look at viper 5701 main connection and did not see any wire come with relay like some other brand I installed b4. ex:compustar /crimestoper vv..so my dumb question is: do i need any extra relay when install this to camry 2007 or does it come with build in relay especially for the starter wire???
Many thanks and forgive me for the dumb question
t&t tech
Platinum - Posts: 2,622
Posted: March 04, 2010 at 8:59 AM / IP Logged
Yes all the relays are built in! No need to use external relays fro the R/S portion!
tommy...
Gold - Posts: 1,901
Posted: March 04, 2010 at 9:04 AM / IP Logged
All the relays are inside the brain...Most units even have a wire for 2nd starter.Acc,Ign...So 10 relays are not required anymore...So Yes...You shouldnt need any relays for the ignition connection(unless no 2nd starter 12v output...or there is just a negative one and need to convert polarity)...I am not real familiar with that unit...So if there is not a wire for 2nd starter...you will probably need to add a relay off the starter wire for the 2nd starter...
Battery BLACK (+) AT IGNITION SWITCH
viper 5701 build in relays? - Last Post -- posted image. Ignition 1 PINK (+) AT IGNITION SWITCH (20 GAUGE)
viper 5701 build in relays? - Last Post -- posted image. Ignition 2 YELLOW (+) AT IGNITION SWITCH (12 GAUGE)
viper 5701 build in relays? - Last Post -- posted image. Accessory 1 WHITE (+) AT IGNITION SWITCH (18 GAUGE)
viper 5701 build in relays? - Last Post -- posted image. Starter 1 BLUE (+) AT IGNITION SWITCH (10 GAUGE)
viper 5701 build in relays? - Last Post -- posted image. Starter 2 GRAY (+) AT IGNITION SWITCH (18 GAUGE)
viper 5701 build in relays? - Last Post -- posted image. Anti-Theft Type UNIVERSAL IMMOBILIZER
viper 5701 build in relays? - Last Post -- posted image. Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM VIA AN ANTENNA RING LOCATED AROUND THE KEY CYLINDER
viper 5701 build in relays? - Last Post -- posted image. Key Sense BLUE (-) AT SWITCH OR BODY ECU 10 PIN PLUG PIN 5
viper 5701 build in relays? - Last Post -- posted image. Tachometer UNCOMMON COLOR (AC) AT INJECTOR OR COIL
viper 5701 build in relays? - Last Post -- posted image. Speed Sense VIOLET (AC) AT ENGINE CONTROL MODULE
viper 5701 build in relays? - Last Post -- posted image. Parking Lights GREEN (+) FRONT OF FUSEBOX viper 5701 build in relays? - Last Post -- posted image.
viper 5701 build in relays? - Last Post -- posted image. Low Crr. Pk Lights BLACK (-) AT SWITCH OR BODY ECU 26 PIN PLUG PIN 23
viper 5701 build in relays? - Last Post -- posted image. Brake Lights BLUE (+) AT SWITCH
viper 5701 build in relays? - Last Post -- posted image. Reverse Lights RED (+) AT NAVIGATION RECEIVER BELOW RADIO OR DRIVER KICK
viper 5701 build in relays? - Last Post -- posted image. Horn BLACK (-) AT COLUMN OR BODY ECU (WIRE MAY BE WHITE AT COLUMN)
M.E.C.P & First-Class
mike08401
Member - Posts: 33
Posted: March 04, 2010 at 9:31 AM / IP Logged
MAny Many Thanks all expert here...That's why I always love the12voltERs with kindness and reliable...viper 5701 build in relays? - Last Post -- posted image.
