2004 pontiac vibe 2 step locks
jrbelanger
Posted: March 13, 2010 at 10:52 AM / IP Logged
Installing an alarm and want to hook up the 2 step lock feature. Do I need to use the "2 step unlock 5 wire alternating door locks" diagram for the relay configuration or "2 step unlock for ground switched door locks" diagram? Being that the locks are negative trigger, I thought I should use the 2 step ground switch diagram. The installation manual for the autopage cs-rs665-2w does not have the 2 step ground switched diagram in it so I'm wondering if I'm thinking wrong. Should use it or the alternating diagram instead. Do I have 5 wire alternating door locks?
jrbelanger
jrbelanger
Posted: March 13, 2010 at 1:45 PM / IP Logged
More simply put, how do I wire up the 2 step door unlock feature on a 2004 Pontiac Vibe using an Autopage C3-RS-665-2W alarm system?
jrbelanger
