bypass the clutch
lowlds10
Posted: March 20, 2010 at 10:51 AM / IP Logged
i'm puting a remote start in a 1999 kia sephia and got everything in and its not starting because  the wire i used to bypass the clutch isn't allowing it to start.  What else can i do? Its  a cs400 remote start/ keyless. which is  made by code alarm. I haven't installed in a 5 spd for over 7 years. Can anyone give me a refresher?
always do your best don't let others bring you down....
Platinum - Posts: 12,488
Posted: March 20, 2010 at 10:59 AM / IP Logged
Did you put the system into reservation mode ?
lowlds10
Posted: March 20, 2010 at 11:36 AM / IP Logged
no i didn't why would i have to put it in that mode?
Posted: March 20, 2010 at 11:42 AM / IP Logged
Remote starters that are designed for manual transmissions have a safety built into them so that you can not start the vehicle in gear. Reservation mode sets up the remote starter so that it is safe to start and vehicle is in nuetral.
lowlds10
Posted: March 20, 2010 at 11:57 AM / IP Logged
i have a ground when the clutch switch is in and i put a custom built plate in for if it is in gear it won't start but when i go to test it its not showing the the switch is in so it just lites up the dash adn doesn't start a cs400 doesn't have that mode it made for an auto.  on the wiring i use a  a blue/blk wire to show a ground for up 4 seconds after the remote start is shut down but its like it doesn't have enough ground but is there anythingelse that i can do to bypass that clutch switch?  i got it to program tach and program the module but its just not remote starting.
chev104275
Gold - Posts: 1,436
Posted: March 20, 2010 at 1:12 PM / IP Logged
use a system that is meant to be used in a standard car   or use a DEI 689M module
Posted: March 21, 2010 at 7:56 AM / IP Logged
Any post containing any information that may be considered a violation of law or lead to an unlawful act in the United States of America such as injuring or killing someone or aiding in theft may be deleted and your membership may be suspended without notice. This includes bypassing head unit lockout codes, video bypass procedures, automatic transmission remote start units in manual transmission vehicles, etc.
