rear fill
nimblecat
Posted: March 27, 2010 at 2:44 PM / IP Logged
I've read posts where some audiophles prefer no rear speakers. I prefer the sound produced by haveing rear fill. I'm currently going to upgrade my systems rear speakers. The factory set up is 6.5 and tweeter on each side, which are located directly under the rear seat armrest firing straight towards the passenger. I will be replacing the factory speakers with MB Quarts 6.5 components, for the mid bass for a subwoofer I'll be using a bazooka tube.
Ok, I am wondering what would be better, use the factory locations or mounting them on the rear deck in an enclosure.
BTW, the front speakers are 5.25 MB Quarts components in a speaker pod in the front doors.
Any help woud be appreciated.
jerome
stevdart
Platinum - Posts: 5,816
Posted: March 27, 2010 at 11:05 PM / IP Logged
Mounting upon the rear deck is an invitation to have your car broken into.  It just is, even if the speakers are walmart road warriors.  Use the factory locations.
BTW, you should realize that the 6.5's should be in the front instead of 5.25's.  The front soundstage should get the lion's share of bass / midbass...but do with what you have to do with.
ianarian
Copper - Posts: 516
Posted: March 28, 2010 at 1:55 AM / IP Logged
Rear fill- "you shouldnt hear it, but you would know if it was missing."   We are genetically engineered to hear the best when facing the direction of the sound. Dominant rear sound travels around the back of the ear causing less sense of the sounds origin. Imaging? I use my rear's for a mid-low.(100-1.4kHz) They pretty much play only drum beats, bass guitar and up to maybe some lower vocal tones. Now if you just want loudness, by all means, more speakers the merrier. The bazooka tube should be in the back dash!
This is what I do for FUN!
nimblecat
Posted: March 28, 2010 at 5:09 PM / IP Logged
thank you for your reply. I've read several dozen of reponse you have given and you are very knowledgeable and i respect your advice.
Yes, i have been on the fence whether to put the 6.5" in the front of the back. from what i read the 6.5" should go in the front.  But, I'm wondering would the 5.25 sound better in a small or limited enclosure then the 6.5?
If i may pick your brain? My components consist of MB Quart components 6.5 and 5.25, a Bazooka 8" Subwoofer, which i choose over the 10 & 12" due to lack of room. Also, my listening tastes is more towards a punchy bass, then a boomy bass, more Rock (I'm a big Who fan, love hearing Kieth Moon banging on those drums) then disco. I also purchased a Hifonics HFEQ, which is a 4 band eq, 9 VOLT Line driver with front and rear active crossovers.
Amplifiers are Alpine 40watts x 4 and 200watt mono (bridged)
I was going to cross the front and rear at 80Hz and the Subwoofer at 80Hz too. Would this be a good place to start and then tweak it from there?
Oh, the Bazooka is going to be facing forward, in the trunk with just the front sticking out thru where the middle arm rest is.
jerome
stevdart
Posted: March 28, 2010 at 5:50 PM / IP Logged
1.  When crossing with 5's, start at 100 Hz.  With 6.5's, 80 Hz is a good place.  Work by crossing over the front soundstage with the sub...the rear fills are added in afterwards.
2.  You shouldn't have any real use for the line driver.  Set your system up without relying on it.
3.  With your tastes, the range of freqs centered at 80 Hz is critical.  This means that you want the front soundstage to accurately and loudly play well down to near the 40's Hz. so that the sound is strong at the crossover region of 80 Hz.  Have plenty of power available for the fronts, use 6.5's, and spend some time tweaking the crossover.  Hopefully, the bazooka will do its job adequately.
4.  Allow the speakers as much room as you can afford them...which indicates door panel use.  Use sound damping on all sheet metal panels of the front doors (the rears are attenuated so not as important in this regard).  This will emphasize the critical 80 Hz crossover region and allow Keith's drums to come to life.  The drawback may be in the light duty amplifier, but Alpine might come across with this if the setup is tight.
nimblecat
Posted: March 28, 2010 at 6:16 PM / IP Logged
thxs, I value your advice and will put the 6.5" in the front with the 5.25 in the back.
I get the impression your not a big fan of  Bazooka Subs?
jerome
ianarian
Copper - Posts: 516
Posted: March 29, 2010 at 4:23 PM / IP Logged
"Bazooka" they are there to serve a purpose, if you like it, purpose served...
Now, that EQ is not something you can necessarily benefit from. Alpine's class AB amps dont respond well to high signal strength. Hi-fonics doesnt make their money in SQ. That EQ has controls like "SPL for Dummies". Your on the smooth level with mellow equipment...kapish? There are other EQ's that may suit better if need be.
nimblecat
Posted: March 29, 2010 at 9:06 PM / IP Logged
 i went with Bazooka to make life easy, i figured the tube would be tuned, instead of purchasing a sub and then purchasing an enclosure which wasnt tuned specifically for that speaker. as for the EQ, all of the reviews were positive and i liked the aux input for an Ipod. thanks for your input on line voltage, i was going to keep the level low.  I'm not a mamaluke, kapish LOL
jerome
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
