mtx amp thunder 4300x rca parts
Barryboy
Member - Posts: 12
Posted: April 02, 2010 at 8:53 PM / IP Logged
Need help finding the RCA female imputs for this amp. Its making alternator noise and the ground for the summed rca's seems to be broken. Any help needed. MTX has no parts. thanks
BRM+MGM+JRM2+SAM Forever!!!
"The ability to reason drives us relentlessly to find the truth." A. Einstein I think????
Platinum - Posts: 13,726
Posted: April 02, 2010 at 9:17 PM / IP Logged
I am not sure if your amp has the RCA jack that has the problem, but there is a common problem with some of their RCA jacks.  The gound connection breaks just above where it attaches so the circuit board.  Simply remove the RCA assembly and solder the leg of a diode onto the piece that the connector broke from.  Then bend it so it will go back into the hole in the board, insert it back into the holes and resolder.
Barryboy
Member - Posts: 12
Posted: April 02, 2010 at 10:12 PM / IP Logged
Great idea! Thanks I will give it a try!
Barryboy
Member - Posts: 12
Posted: April 06, 2010 at 1:52 PM / IP Logged
I was able to solder the new leg and insert into circuit board as you said. Thanks Now to reinstall to see if this works! Will let you know. Will save alot of money!!!
Barryboy
Member - Posts: 12
Posted: April 18, 2010 at 2:11 AM / IP Logged
Worked perfect no more whine. You are a genius!! Thanks
Posted: April 18, 2010 at 6:02 AM / IP Logged
Make sure you keep the RCA mounting screw tight.  That will prevent this from happening again.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
