better amp for rockford p3
krazytiger
Posted: April 10, 2010 at 5:03 AM / IP Logged
i i just pick up 2 Rockford Fosgate P3 12in (P3D412 ) in  a ported box, im just wondering, which amp i should get for them?
ianarian
Copper - Posts: 516
Posted: April 12, 2010 at 12:32 AM / IP Logged
This one: T20001BD - Rockford Fosgate
This is what I do for FUN!
tedmond
Gold - Posts: 4,610
Posted: April 13, 2010 at 6:49 AM / IP Logged
the fosgate amp is a monoblock with over 1500watts rms and 2000 at 1ohm. since these are 4ohm dvc, you can go for a combined load of 4 ohm or 1 ohm, but the rms of both subs would be approx 1000w +- 5%
the output of the 20001db is much greater, increases chances of blowing, but it sure is enough power to run those hard.
Ted
Compustar Expert
ianarian
Copper - Posts: 516
Posted: April 13, 2010 at 10:20 AM / IP Logged
Awww crud, I meant to post the T50001BD, that would of made more sense! better amp for rockford p3 - Last Post -- posted image.   Without a budget or some dimensional size limitations, I figured I'd aim high!
krazytiger
Posted: April 13, 2010 at 1:13 PM / IP Logged
there is no dimensional size limits but i was hoping for something closer to 500$ and under
ianarian
Copper - Posts: 516
Posted: April 14, 2010 at 5:48 AM / IP Logged
Ya you dont quite need the T15k, but it would be cool to ownbetter amp for rockford p3 - Last Post -- posted image.
Well, why not just stay Fosgate... If a shop installs it, you will get your money's worth in use by the time the warranty period expires... If you nook it, Fosgate and better companies the like are less reluctant to extend any special courtesy's.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
