mono block amps , 4ohm dvc subs
jimmerj18
Posted: April 10, 2010 at 3:03 PM / IP Logged
I have 2 Rokford Prime R500-1 Amps and i want to run each Amp to a pair of 4ohm dvc 8" subs will this work ? And how should i wire them so i can get a 2 ohm load ? or is this possable i see i can do this and get a 4ohm load in your diagrams .but not shure about the Mono Block Amp.or do i need 2 channel Amps ?
James Lyons
jimmerj18
Posted: April 10, 2010 at 3:04 PM / IP Logged
My Truck is a 1999 Ford Ranger Extra Cab
James Lyons
stevdart
Platinum - Posts: 5,816
Posted: April 11, 2010 at 9:00 PM / IP Logged
A DVC 4 ohm sub can be 8 ohms or 2 ohms, using both coils.  If you have two of these subs, the impedance will come out to be 4 ohms when you combine them.  Put this 4 ohm combined load onto the mono amp and don't worry about getting that li'l bit of extra that you might get with the 2 ohm impedance.
Whether your amp is class D mono or class AB two channel, the impedance of your combined speakers is still the same.  For the purpose of amplifying subsonic freqs, the class D amp is the most efficient (more than a two channel amp).  The value of that extra efficiency on you car's power supply is greater (for you) than changing amp types so that you can load the amp to its limit.
But if you cannot be happy unless you are loading an amplifier to its limit ("getting your money's worth"), then go ahead and sell those mono amps and buy two 2-channel amps...where you will wire a parallel-wired DVC sub onto each channel at 2 ohms (per channel).
jimmerj18
Posted: April 12, 2010 at 12:22 AM / IP Logged
i want to thank [stevdart] for the answer to my question. Steve explained it so rookies like me could understand
Thank Very Much mono block amps , 4ohm dvc subs - Last Post -- posted image.
James Lyons
stevdart
Posted: April 12, 2010 at 5:38 PM / IP Logged
You're welcome.  :)
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
