running two stereos in car
johndbb
Posted: April 13, 2010 at 5:25 AM / IP Logged
Hi all
Looking to running two stereos (OEM unit connected to CD changer and an Alpine IDA X305 dedicated mp3 unit) in my 2001 Golf
I guess I would need a relay for each speaker connected to the amp power send of the second unit to switch the speakers over but what options would i have on powering the units themselves? Is it simply a case of running another wire from the battery for the second unit or can i use the one thats already there somehow?
tedmond
Gold - Posts: 4,610
Posted: April 13, 2010 at 6:40 AM / IP Logged
use a harness and connect both together, but leave the connection 12v connection untouched. Run a 10-12 gauge wire from the battery fused at 20 amps to the deck area, then run your constant 12v sources off of that.
that way you dont have to worry about turning both on and blowing the radio fuse.
just remember, use one or the other only.
Ted
Compustar Expert
awdeclipse
Copper - Posts: 285
Posted: April 13, 2010 at 7:18 AM / IP Logged
Perhaps adding a "selector switch" that connects to the ground would help prevent trying to power both units at once and remove the need to add a bunch of relays to switch over the speaker outputs.
However if you are interrupting power to one unit or the other, no presets for you...
I guess you could switch the ignition wire instead then, so you could maintain preset memory and then toggle between which radio you want to use. A SPDT switch would work fine for this.
1 - Stock Radio
2 - Switched Ignition
3 - Alpine Radio
oldspark
Gold - Posts: 4,913
Posted: April 13, 2010 at 10:36 AM / IP Logged
awdeclipse wrote:
Perhaps adding a "selector switch" that connects to the ground...
If by that you mean "breaking" the GND connection(s) - don't - because units still GND thru other paths. (Unless you know they are fully GND isolated except for their power/chassis connection.)
Ween
Platinum - Posts: 1,368
Posted: April 13, 2010 at 12:09 PM / IP Logged
two 4PDT relays to isolate/select the four channels of speakers, wire the relay coils in parallel connected to the remote out lead of the Alpine.  NO contacts of relays to the Alpine hu, NC contacts to the OEM hu, C contacts to the vehicle speakers.  may need to boost the output of the remote lead with a trigger module, depends on current output available on Alpine and relays used.  should be fine powering both headunits with stock wiring. Alpine unit has priority over OEM unit.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
