2007 sonata v6
grundler1975
Member - Posts: 29
Posted: April 13, 2010 at 9:14 PM / IP Logged
I am installing a NAV radio in my wifes car. I can't find the VSS wire location, parking break wires( without getting into the console, and the reverse wires. Any help would be great! Thanks
flobee4
Silver - Posts: 585
Posted: April 13, 2010 at 10:56 PM / IP Logged
I looked up the car on Directechs and it shows the Parking brake as orange on the right hand side of the fuse box. There are a 4 plugs plugged in there on the right hand side. Its in the top most plug toward the firewall. 12 pin plug, pin 9.
As for the VSS, its yellow at the Diagnostic Plug under the drivers dash, pin 6
Reverse Wire is Blue in the drivers side wiring harness heading to the rear of the car. It also says it is located in the 18 pin brown plug in the drivers kick panel, pin 7
Frank
Monday, August 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
