1996 ford f350 diesel
towmannick
Member - Posts: 6
Posted: April 16, 2010 at 9:56 PM / IP Logged
Need help with installin a auto page rs-1000 on a 1996 ford f350 diesel. Same wiring as a F150??
Tach wire the same???
chev104275
Gold - Posts: 1,436
Posted: April 18, 2010 at 8:24 AM / IP Logged
1996 FORD F350 EXTENDED CAB TRUCK
Security
WIRE COLOR POLARITY LOCATION
Battery YELLOW (+) IGNITION SWITCH HARNESS
Ignition 1 RED / LIGHT GREEN (+) IGNITION SWITCH HARNESS
Starter 1 RED / LIGHT BLUE (+) IGNITION SWITCH HARNESS
All Door Trigger BLACK/ LIGHT BLUE (+) DRIVER'S KICK PANEL
Trunk Trigger N/A
Alarm Disarm DARK GREEN/ VIOLET
Parking Lights BROWN (+) LIGHT SWITCH OR DRIVERS KICK
Convenience
Headlights-Lo RED / YELLOW (+) AT LIGHT SWITCH
Trnk Release N/A
Remote Start
Ignition 2 GRAY / YELLOW (+) IGNITION SWITCH HARNESS
Accessory 1 GRAY / YELLOW (+) AND BLK/GRN IGN SW HAR "BLK/GRN FOR AC"
Anti-Theft Descript NONE
Key Sense BLACK/ PINK (-) STEERING COLUMN HARNESS
Neutral Safety NOT GROUNDING
Tachometer TAN / YELLOW (-) AT IGN SW CONTROL MOD "DRV FENDER WELL"
Speed Sense GRAY/BLACK (AC) PIN 3 AT PCM MOUNTED THROUGH FIREWALL
Brake Lights LIGHT GREEN (+) AT BRAKE SWITCH
Reverse Lights BLACK/ PINK (+) SWITCH ON TRANSMISSION
Horn DARK BLUE (-) AT STEERING COLUMN
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock PINK/LIGHT GREEN (-) REVERSE POLARITY "USE DRV SW TO TEST"
   (REV) ON MODELS WITHOUT KEYLESS
PowerLock PINK / YELLOW (-) PASS KICK W/KEYLESS NEG TRIG W/OUT KEYLE
LF Window Up LF:WHITE/ BLACK
RF Window Up RF:WHITE/ YELLOW
LR Window Up LF:YELLOW
RR Window Up RF:TAN/BLUE LR:YELLOW/BLUE RR;YELLOW/BLACK
Note: Code Systems makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Code Systems disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
NOTE *2 The DIESEL TACH wire is a WHITE/ PINK and the WAIT TO START is a BLACK/ PINK (-) both wires are located at the PCM (Powertrain Control Module) or at the MAIN HARNESS that runs on the inside of the firewall to the left of the brake pedal. The WAIT TO START wire MUST BE DIODE ISOLATED,
AS Always Tes With A DMM To Verify Wire Colors
towmannick
Member - Posts: 6
Posted: April 18, 2010 at 9:14 AM / IP Logged
Thank you. 1996 ford f350 diesel - Last Post -- posted image.
