identifying relay pins
juavos00
Copper - Posts: 66
Posted: April 17, 2010 at 5:18 PM / IP Logged
First off sorry for the crappy paint drawing, but thats as good as I could do. Anyway I need help identifying the pins on this relay. (85,86,87,87a,30) Thanks
identifying relay pins - Last Post -- posted image.
t&t tech
Platinum - Posts: 2,622
Posted: April 17, 2010 at 5:27 PM / IP Logged
85- Negative side of relay coil*
86- Positive side of relay coil*
30- Common terminal of relay,
87a- Normally closed terminal (closed to pin 30 when relay is inactive, and open when active)
87- Normally open pin, (open when inactive, closed to pin 30 when relay is active)
*Applying power and ground to the respective termnal activates the relay!
t&t tech
Posted: April 17, 2010 at 5:29 PM / IP Logged
In the diagram you have however
Pins 1 and 2 would be the coil
pin 3 is common, 4 is normally closed and 5 normally open!
juavos00
Copper - Posts: 66
Posted: April 17, 2010 at 5:30 PM / IP Logged
thanks for the reply, but that doesn't help me much. I know about what each pin does, but that is why I drew the picture with the numbers on them hoping someone would say.. 1 = 85 2 = 86, so forth and so on.
Also does it matter if the positive and negative are switched?
juavos00
Copper - Posts: 66
Posted: April 17, 2010 at 5:31 PM / IP Logged
sorry couldnt post before you answered my question..
But does the positive and negative matter?
oldspark
Gold - Posts: 4,913
Posted: April 17, 2010 at 7:30 PM / IP Logged
Not in this case - you relay uses a resistor across the coil (not a diode to quench the coil spark).
Platinum - Posts: 13,725
Posted: April 17, 2010 at 9:09 PM / IP Logged
1 = 85
2 = 86
3 = 30
4 =87A
5 = 87
Posted: April 18, 2010 at 12:21 PM / IP Logged
I think that relay is Italian, the convention is pin 1 (85 on the ISO listing) is normally the neg. side of the coil.
t&t tech
Posted: April 18, 2010 at 3:25 PM / IP Logged
My bad!  You should have explained yourself better!
juavos00
Copper - Posts: 66
Posted: April 18, 2010 at 8:03 PM / IP Logged
I have wired in my relay thanks to all of your help.. Mods can you please lock and/or delete this thread. Thanks
