python 1400xp civic alarm problems
lopezchris21
Member - Posts: 21
Posted: May 24, 2010 at 10:08 PM / IP Logged
Hey guyz. Im in process of installing this alarm with remote start and this is duch a hassle.
I went and plugged most everything up except for auxiliary harness (h2) and the remote start auxiliary harness wiring.
I think i connected everything else right. The car will start but the actual remote will not work. my lights will not flash when i press the lock or unlock button. I do not have power locks but i tried to set up the light so it honked and flashed with alarm. this is how i plugged them in. I also did not use the relay because it came with a paper that said applications and civic wasnt on there. I tried to plug it in and leave the other wires not spliced not connected but it still didnt work.
cars is a 93 civic si hatch
feel free to call me with any info. 813-220-3061
any help is much appreciated
H1
RED / White - n/a
Red- BLACK/ white IGN harness
Brown - blue/red horn relay
Black - chassis ground
Violet - n/a
Blue - n/a
Green - n/a
BLACK/ White - n/a
WHITE/ Blue - hood pin
White - RED / black on dimmer switch
Orange - n/a
H2
violet/black - n/a
GREEN / WHITE - n/a
gray/black - n/a
light GREEN/ black - n/a
Door Lock
no connected
Relay Satellite (ribbon harness)
- connected
H3
BLACK/ White - spliced into ground
Violet/White - blue wire on cluster plug
Brown - GREEN / WHITE brake switch
Gray - spliced into hood pin
Blue/White - n/a
H4
blue - n/a
green - n/a
Relay Satellite
Purple - BLACK/ white IGN starter side
Green - BLACK/ white IGN key side
Red - white IGN harness
Orange - n/a
Pink - BLACK / YELLOW IGN harness
Pink/White - n/a
RED / White - white IGN harness
i really need some advice guyz. Why in the world would my lights not turn on anymore. Also on the plug connected to the light switch there is one cord that was stuck into a hole in the srs airbag plug. I have a sir steering wheel so i have no airbag.
lopezchris21
Member - Posts: 21
Posted: May 24, 2010 at 10:12 PM / IP Logged
n/a = not connected
lopezchris21
Member - Posts: 21
Posted: May 25, 2010 at 12:21 AM / IP Logged
27 views guys. at least if i could get my headlights to work ill be happy. for now..
t&t tech
Platinum - Posts: 2,622
Posted: May 25, 2010 at 4:25 PM / IP Logged
You have alot of things to correct! Starting with the red on the h1 harness that connects to the thick gauge white wire at the ignition harness! The WHITE/ blue on h1 doesn't connect to the hood pin either, only the grey hood pin wire connects to the hood pin! Never use dimmer control parklight feeds! If you look at your fuse box from left to right you will see a few empty relay pin slots, the second from the left is a prking light feed to trigger the lights (positive trigger) test to verify!
This car is easy as it ges! The door locking module is in the driver door! I think you need an actuator for keyless!
t&t tech
Posted: May 25, 2010 at 4:27 PM / IP Logged
Also deducing from your post i can tell you are spanking brand new at this, so on the light issue, have you connected the plug at the stalk if yes, check your fuses, there are two boxes one under the dash and the other in the engine bay!
lopezchris21
Member - Posts: 21
Posted: May 25, 2010 at 10:11 PM / IP Logged
Ok i fixed the head lights and i rewired the red to the constant 12v which is the fat white one and the alarm blinks and stuff now. sometimes it doesnt work and sometimes it doesnt. Also in manual it says that when the orange is hooked up it will send a negative power to the box which is the cut off. When i ground it out my car wont turn on at all. when i take it off the ground it starts fine. Also my light for my alarm is constantly on. It doesnt go off....
If it will make it easier please call me 813-220-3061
