07 tahoe, prestige aps997n remote start
eddie302
Posted: July 22, 2010 at 11:48 PM / IP Logged
I'm working on a 07 mexican tahoe and am installing a prestige aps997n reamote start, but can't get the thing to power up the main harness when i press the remote start twice, can someone help me?
eddie302
Posted: July 23, 2010 at 12:11 AM / IP Logged
i'm thinking i'm connecting something wrong, bad module, or the alarm is not compatible with the mexican truck. wires are not the same color but some are still in the same position, no obd 2 violet wire though, i'd appreciate some advice here.
lectricguy
Copper - Posts: 359
Posted: July 23, 2010 at 5:24 AM / IP Logged
eddie302-
  Have you confirmed the wiring with a volt meter?  I would remove the 6 pin ign connector from the remote start and check with a volt meter while turning the key to the acc, on, and start positions, and confirm the correct signals are present based on the remote start colors.  Also confirm the Brake and Hood signals/sense, as well as system ground.
If the correct signals are present, you need to confirm the tach connection and program the tach.   The unit will not start if the tach isn't programmed.
Also, if you are using voltage sense, you will need to program the unit for voltage mode, then start the vehicle with a key at least 4 times to learn crank time before the unit will remote start.
Lectric Guy
