python 592 problem, ideas?
cxpcman
Posted: July 26, 2010 at 10:34 AM / IP Logged
i just install all the wiring for the python 592 but it doesn't work . no led flashing, and the remote says out of range . connections seem to be ok .. so my question is .. im trying to figure out the problem so i just connect +12v, ground, valet-led-antena, siren. this is the minimum required to make it work right ? if somebody have an idea let me know
KPierson
Platinum - Posts: 3,527
Posted: July 26, 2010 at 1:53 PM / IP Logged
That should be all that is needed to make it flash the lights and lock the doors (and chirp on arm and disarm)
Kevin Pierson
cxpcman
Posted: July 26, 2010 at 2:34 PM / IP Logged
i reduce all the wiring to just that +12,gnd,antena,siren,neutral switch(on position) and nothing.. this is very annoying ...
It doesnt have jumpers that need to be removed, change. fuses ?
first time an alarm makes me work that much ..
KPierson
Posted: July 26, 2010 at 2:41 PM / IP Logged
You shouldn't have to do anything else.  I would take it back to the store you purchased it from and exchange it.
Kevin Pierson
ruki101
Copper - Posts: 65
Posted: July 26, 2010 at 7:35 PM / IP Logged
Listen to Kevin's advice, just return or exchange the unit but, you can also try programming the remote control to the control box. See install manual for details on how to reprogram remotes. This happened to me a while back and thats all I did to make it work. Goodluck!!
Just About Anything Sparks
