06 toyota tundra, keyless entry
hallkt
Posted: August 13, 2010 at 5:39 PM / IP Logged
Can some one help me with wiring my 2006 Toyota Tundra with an aftermarket keyless entry. My vehicle did not come with a keyless antry and im having a hard time finding out how to install this and how to begin.
Thanks,
Trevor
Platinum - Posts: 7,828
Posted: August 13, 2010 at 8:17 PM / IP Logged
Not sure where to begin.
Does the Tundra have factory power locks?
What brand and model keyless entry?  Is it an alarm and/or remote start also?
Here is a link to Bulldog Security for a wire guide for your truck:  http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
It will give you wire locations and wire colors for the necessary wires.  Remember, this is only a guide.  All wires should be verified with a Digital Multi Meter ( and all connections soldered ).
Mike M2
Platinum - Posts: 2,652
Posted: August 15, 2010 at 5:17 PM / IP Logged
Also, the Tundra came in two types in 06. The standard cab and extended cab wiring are different than the 4 door. The 4 door will require a relay in the drivers door to work the locks(or a module).
Mike M2
Tech Manager
CS Dealer Services
