2001 nissan pathfinder oem navigation
ilikebeans
Posted: August 30, 2010 at 12:09 PM / IP Logged
I found this forum looking for information on my navigation system.  It is the factory original piece.  The buttons have fallen off, which this unit is prone to do.  I hadn't bothered replacing the unit since I don't really use it and the car is almost 10 years old.  Now, however my AC has stopped working and the AC control unit and the navigation are one system.  I can't get the error code without a functioning unit.
I found a unit in a junk yard halfway across the unit, which is on its way.  I need help with removing the old unit and installing the new one.  If there is any information, or guides you can point me towards it would be appreciated.  I don't have any experience doing this type of work, but I do know a little about mechanics.
Thanks for any help you may be able to offer.
91stt
Silver - Posts: 564
Posted: August 30, 2010 at 2:10 PM / IP Logged
This should help
Metra 99-7417 manual
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
ilikebeans
Posted: August 30, 2010 at 2:39 PM / IP Logged
Thanks.  That will definitely help.
ilikebeans
Posted: August 30, 2010 at 3:23 PM / IP Logged
One more question please.  I can't figure out how to unclip the clock/vent assembly.  This is step A.  It looks like the rest should be pretty easy.
Thanks again for any help.
91stt
Silver - Posts: 564
Posted: August 30, 2010 at 3:31 PM / IP Logged
You should be able to remove the vent assembly with a screwdriver by prying it out on the top
