Posted: September 16, 2010 at 12:11 PM / IP Logged
Posted: September 16, 2010 at 5:49 PM / IP Logged
Posted: September 16, 2010 at 10:19 PM / IP Logged
Posted: September 16, 2010 at 10:44 PM / IP Logged
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Assuming common commons (ground) and stereo, you require a DPDT switch.
Think of it as 2 poles (sides or circuits) and each pole has 2 positions aka Throws (hence 2P2T or DPDT = Dual Pole, Dual Throw - where T = Throw is position.
So one throw/position is from CB; the other from iPod. The centre goes to the audio in.
The same is done for the other channel on the other Pole (with CB left adjacent to CB right etc).
The common for all are connected together.
If that is not allowed (for ground loop other reasons), then an extra pole is needed to connect them the same way as the left & rights.
Hence a 3PDT switch is required.
I'll assume that separate right and left returns (commons, -, etc) are NOT required - that usually requires isolation (transformers etc).
You should be able to find this covered complete with diagrams...
It is a common situation.
