crimefighter alarm door locks wiring
skyline_man
Member - Posts: 35
Posted: September 19, 2010 at 11:14 AM / IP Logged
I'm trying to install a Crimefighter alarm system into a friend's 1996 Subaru impreza WRX and i am stuck at the door lock section.
Now most alarm systems I have work with has only 2 outputs for the doorlocks. The crimefighter has something like 5 different wires for the doorlock. Futhermore, the installation manual doesn't explain much about wiring the door locks.
My friend's WRX has a aftermarket door lock kit installed.
here is the Crimefighter's manual
https://www.the12volt.com/installbay/file.asp?ID=745
skyline_man
Member - Posts: 35
Posted: September 19, 2010 at 11:19 AM / IP Logged
sorry, i don't know how to use the features on this forum to upload the diagram. Here is a past post by a member. scroll down to the post by loneranger. He has uploaded the manual
https://www.the12volt.com/installbay/forum_posts.asp?tid=110759&get=last#535690
Posted: September 19, 2010 at 11:37 AM / IP Logged
First does your vehicle have key less entry?
If so just read the instructions where it shows "5 wire" wiring. The keyless entry wires and module should be in the driver's kick panel.
If not wire as "adding an actuator (motor)".
You will need one in the driver's door. If you PM me with your email address I can show you photos of an install on a R/H/drive car.
Lastly failing a diagramme, are your lock wires marked common, NC, NO etc.?
List them and it should be 6 not 5.
Posted: September 19, 2010 at 11:55 AM / IP Logged
Just looked at the download, if keyless find the motor wires in the DKP
Both will sit on ground (earth, 1 will go to 12volts on lock, the other will go to 12volts on unlock). Cut these wires, then..
WHITE/ black to lock module side of motor lock wire.
GREEN/ black to door side of same.
PURPLE / black and purple to 12v+ power supply of module or source via 20 amp fuse from fusebox feed etc.
BROWN / black to lock module side of unlock motor wire.
Blue/black to door side of same.
If you have to add a motor wiring is exactly the same except GREEN/ black and blue/black go to the motor and WHITE/ black and BROWN / black go to ground, also this time a 7.5amp fuse is adequate.
skyline_man
Member - Posts: 35
Posted: September 20, 2010 at 4:15 AM / IP Logged
Thank you so much, the door lock works perfectly. You're a legend!
Now all I have to do is figure out how to disable that annoying parking light flashing whenever I leave the door open
