96 accord remote start/ alarm
sikauto
Posted: September 25, 2010 at 1:43 AM / IP Logged
Ok so im doing my first alarm/remote start. Its going into a 96 Honda Accord LX automatic alarm is a Prestige Aps997A. So far i have the complete alarm part done. Wasnt too bad but did take me a while seeing as it was my first alarm. Now i came into a problem with the remote start. I wired up the realy as it stated and thought i had everythin ok untill i tried to start it. Every time i hit the remote start button it says Inhibit on the remote. Not sure why thought i had all the connections ok althoi couldnt find the neutral saftey switch. So idk if i even have it wired up right to begin with. Any help will be greatly appreciated.
sikauto
Posted: September 25, 2010 at 1:48 AM / IP Logged
Also i couldnt figure out where to put the yellow starter output wire at from the 6 pin harness on the alarm
Platinum - Posts: 7,828
Posted: September 25, 2010 at 3:35 AM / IP Logged
The heavy gauge Yellow wire from the 997a goes to the Accords' (+) Start wire which should be BLACK/ White at the ignition switch harness.  Test with a Digital Multi Meter to verify.
sikauto
Posted: September 25, 2010 at 10:10 AM / IP Logged
Yup i have that wire connected to the blk/wht.
godd dan it
Copper - Posts: 447
Posted: September 25, 2010 at 7:07 PM / IP Logged
You can ground the neutral safety switch wire on the alarm.
