09 galant need wiring diagram
drod1977
Posted: September 26, 2010 at 1:58 PM / IP Logged
does anyone have a wiring diagram for a remote start for a 2009 galant? thanx to all in advance.
Platinum - Posts: 13,725
Posted: September 26, 2010 at 9:31 PM / IP Logged
Parking lights must use both wires listed and diode isolate the 2 wires.
WIRE COLOR POLARITY LOCATION 09 galant need wiring diagram - Last Post -- posted image.
09 galant need wiring diagram - Last Post -- posted image. Battery BLUE / YELLOW (+) IGNITION SWITCH HARNESS
09 galant need wiring diagram - Last Post -- posted image. Ignition 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
09 galant need wiring diagram - Last Post -- posted image. Accessory 1 BLUE/RED (+) IGNITION SWITCH HARNESS
09 galant need wiring diagram - Last Post -- posted image. Accessory 2 BLUE/BLACK (+) IGNITION SWITCH HARNESS
09 galant need wiring diagram - Last Post -- posted image. Starter 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
09 galant need wiring diagram - Last Post -- posted image. Anti-Theft Type UNIVERSAL IMMOBILIZER
09 galant need wiring diagram - Last Post -- posted image. Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
09 galant need wiring diagram - Last Post -- posted image. Key Sense BLUE/RED (OPEN) IGNITION SWITCH HARNESS 09 galant need wiring diagram - Last Post -- posted image.
09 galant need wiring diagram - Last Post -- posted image. Tachometer YELLOW/RED (AC) AT INJECTOR #1 09 galant need wiring diagram - Last Post -- posted image.
09 galant need wiring diagram - Last Post -- posted image. Speed Sense GREEN/ YELLOW (AC) AT PCM MODULE BEHIND DRIVER HEADLIGHT
09 galant need wiring diagram - Last Post -- posted image. Parking Lights GREEN / WHITE & GREEN/ ORANGE (+) IN HARNESS IN DRIVER SILL PANEL 09 galant need wiring diagram - Last Post -- posted image.
09 galant need wiring diagram - Last Post -- posted image. Brake Lights GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
09 galant need wiring diagram - Last Post -- posted image. Reverse Lights RED / BLUE (+) IN HARNESS IN DRIVER SILL PANEL
09 galant need wiring diagram - Last Post -- posted image. Horn LIGHT GREEN (-) AT THE ETACS MODULE UNDER DRIVER SIDE DASH
09 galant need wiring diagram - Last Post -- posted image. Rear Defrost WHITE/ BLACK
