multiple amp power wiring
slowdoo72
Posted: October 18, 2010 at 9:40 PM / IP Logged
I have a question about proper wire guage size when wiring multiple amps.  I considered running 1/0 from battery for power to a block and down sizing to #4 to my four amps. Then running four seperate #4 grounds back to chassis. Does anyone have any input. Or should I run four #4 for power instead? thanks
k
mrm1776
Copper - Posts: 100
Posted: October 18, 2010 at 10:13 PM / IP Logged
What kind of amps are you runnings? Model numbers or specs, please.
MECP Basic Installation Tech
Certification ID: CEA195600
Pioneer AVIC-X920BT
Polk Audio DXi 6500 - front
Rockford Fosgate Power T1693 - rear
Alpine MRP-F300
Alpine MRP-M500
Alpine SWR-1242D
stevenje98
Member - Posts: 28
Posted: October 21, 2010 at 11:41 PM / IP Logged
Post your amplifier specifications all 4 of them.
Once your figure out the total watts you can figure the current needs using ohms law to size your main power cable. At this point I think you should also take into account how much power you Alternator are putting out to see if you can deliver the correct power off your alternator. If not then you might think about using a different amplifiers or a larger alternator.
Post your amp specification first
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
